enum string to string
What is the best way to write a selection ring with a text label and command
Remote Input 1(label), RemoteInp_Value(command)
I was thinking of using enum but not sure how since I want to use two strings.
Soren
(2,232 Views)
Soren
For Enum, Writing the Strings is writable only during edit mode. if you no need to update the strings during runtime and its just for selection you can use enum.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,219 Views)
Accepted by topic author Soren74
You can use the "StringsAndValues" Property Node to change the text in a Text Ring programmatically.
=== Engineer Ambiguously ===
(2,185 Views)
