envelope in real-time
I want to calculate the envelope of the amplitude of a signal in real-time. Initial testing with the Hilbert transform has been unsatisfactory. I now square the signal, detect the maxima of the squared signal and do an interpolation on these maxima to recover the envelope of the signal. However, this results in an unacceptable delay of 1/2 signal period. How can reliably calculate the envelope a signal in real-time?
Best,
Michiel
(3,227 Views)
Hello Michiel,
I see you tried to implement the Hilbert Transform.. DId you write this your self our did you try an example program? IBellow I put down a link to an example VI which does a Hilbert Transform. Did you see this VI before and does it also not do what you want to achief? The link:
http://zone.ni.com/devzone/cda/epd/p/id/1346
RikP - National Instruments Applications Engineering
Rik Prins, CLA, CLED
Software Development Engineer
(3,201 Views)
Thank you for your reply. I indeed tried the example vi. However, i know found what i did wrong in initial testing. I took the square root of the signal before applying the Hilbert. Results are much better now. However, still one question: if I apply a signal that contains transients (say a sawtooth of 200 units in amplitude) the Hilbert results in a signal that has peaks up to 600 units. Is there any way compensate reliably for transients?
Michiel
(3,189 Views)
Any suggestions on implementing the Hilbert transform in real-time are more than welcome. I'm kind of struggling with this issue.
(3,180 Views)
