epoch time calculate
hi,
      how to calculate epoch time in current time stamp based(in 1970 jan 12:00 clock time based)
Message 1 of 8
(5,690 Views)
Hi Gokul,
to get the number of seconds since 01.01.1970 yu just subtract that timestamp from current time…
Does this answer your question?
Message 2 of 8
(5,671 Views)
hi,
       but i can't set 00:00:00 1/1/1970 in constant variable.here attached my exampe.if i set 12:00:00 1/1/1970 it give some second difference value show.
Message 3 of 8
(5,654 Views)
Hi Gokul,
why can't you set 00:00:00 in your timestamp?
I can:
Be aware of the timezone dependency of the timestamp control/constant!
Message 4 of 8
(5,645 Views)
hi,
      i try to change(00:00:00:000 1/1/1970) it automatically change 5:29:59:000 1/1/1970
Message 5 of 8
(5,632 Views)
What happens when you input "31.12.1969 18:30:00"?
Again: this is related to the mentioned timezone dependency of the timestamp in LabVIEW!
Message 6 of 8
(5,609 Views)
The difference between Y1970 and Y1904 is 2082844800 seconds regardless of time zone. Since the "Get Date/Time In Seconds" VI is UTC, then the output UNIXEpochTime is also in UTC. Ensure that the U32 representation is used to avoid the Y2038 problem.
Message 7 of 8
(4,423 Views)
Here's something that might help, I found this a long time ago when trying to convert LabVIEW raw timestamp to an "Excel" Timestamp
The OLE (Excel) date format is a double-precision floating point number that counts the time from 30 December 1899 00:00:00.
Thus, a value of 0.0 corresponds to 30 December 1899 00:00:00.
The UTC date that is returned from the LabVIEW functions is the number of seconds elapsed since 12:00 a.m., Friday, January 1, 1904.
Thus, in this case, a value of 0.0 corresponds to 01 January 1904 00:00:00.
This means you have an offset between a LabVIEW timestamp and the OLE date.
Basically, whatever date you get from LabVIEW you need to add the number of seconds between 30 December 1899 00:00:00 and 01 January 1904 00:00:00 to get the corresponding OLE date value in floating point.
=== Engineer Ambiguously ===
Message 8 of 8
(4,417 Views)
