equcation
Hi all,
I have a problem with the calculation of an equcation.
The equcation is y=d0+d1*c+d2*x+d3*x^2 where c is a known constant and x is a series of points( an array).
Then, I would like to calculate the values of y and use the regression graph to calculate back the d0,d1,d2 and d3.
Actually is it possible to it?Smiley Sad
Thanks in advance
Io
(4,162 Views)
Hi IO,
how do you want to calculate the y value without knowing the values of d0 to d3? Or is y the index of your x Array * dt?
Mike
(4,155 Views)
Dear Mike,
Thanks for your reply.
Actually in the first place, I think I have a series of x then I use those x to calculate the variation of y because the coefficients are constant .But I  forget the most impaortant part is the y is not  constant indeed.As a result of that, the equcation is not possible for the solution.I am sorry that I have made a terrible mistake.
Now, I will look at the equcations to calculate the y values first.then, use teh regression graph to calculate back the coefficients.
Thanks a lot.Smiley Happy
Io
(4,147 Views)
Hi IO,
to calculate the y values you can use the LabView functions. See the attched example. Hope this helps.
Mike
(4,142 Views)
Dear Mike,
The VI is very useful.Thanks a lot.
Io
(4,132 Views)
