erreur -1073807195
bonjour,
j utlise la version 7.1 de labview et je voudrais commander un system par le port serie,j ai les drivers mais lorsque je lance mon appl, j ai le l erreur -1073807195....avec type d interface valide, mais le numero d interface specifie n est pas configure?
Quel est ce numero d interface? lka sub adresse de mon systeme a comander?
merci
(2,662 Views)
French to English (Thanks to google)
hello,
j utlise version 7.1 labview and I would like to order a system by the serial port, I drivers but when I run my appl, I l error -1,073,807,195 .... type of interface with valid, but the number of specifies interface is not configured?
What is the number of interface? lka sub address of my system a command?
thank you
(2,661 Views)
(2,660 Views)
