error 10001
Exe file was created in LabVIEW on win 2000 with following hardware
PCI 6052e
Scxi 1000 chaises
Scxi 1303
Scxi 1324
Scxi 1325
Scxi 1326
It was working OK until computer stopped working
Then this program was installed on new computer with xp sp2 on execution it shows error 10001. Engineer who designed is not available. Chaises and modules shown in max.
I am not sure how to solve this problem.
Nidaq7 max3
Configured in both traditional daq or nidaqmax
Hoping for help
Salman
(4,134 Views)
That is an error from the traditional daq driver. You shouldn't even have DAQmx installed. Uninstall it and then check the channel name and make sure that the name in MAX is the same as in the code.
(4,125 Views)
i removed them from ni daqmax. and configured all in trd ni daq   MAX. then for moment it shows error :
10001 occured at DIO port config,  an error was detected in the input string: the rrangement or odering of the chracters in the string is not consistant with expected ordering.
but if i say to continue every second again and again neglecting fault  analogue display on screen  show reading changes every second with fault to continue
when i configured modules
chaises id =1, chaises address= 0
for scxi 1303
cabled device to 6052
operaing mode : multiplex
attached access: scxi 1102c
for 1325
cabled device : nil
attached access: scxi 1124
for 1326
cabled device : nil
attached access: scxi 1162hv
for 1324
cabled device : nil
attached access: scxi 1160
in Ni daqmax it was not showing readings
do i need to configure indivisual channels??? input and outputs????? and how to know
(4,099 Views)
Hi
Hope to get help from you
(4,041 Views)
