error 10401 on PCI MIO 16 E1
I use a PCI-MIO-16E-1 DAQ card and I try to configure a buffer and write 2000 points in the FIFO. I've installed all drivers and the last version - I think - of MAX (august 2003), but LabVIEW 7.0 indicates that a -10401 error occured.
(just for information, my OS is NT 4.0 ...)
Can you explain me why ?
(2,694 Views)
does this device show up in MAX ?? if so does it pass the Test Resources in the property window ??? also do you have the pnpisa driver for NT installed ?? if not its in the i386 drivers directory on the nt disk(if i remember correctly , its been a couple of years) and make sure you are referecing the proper device in LabVIEW...
Dan
(2,694 Views)
After checking everything is right installed in MAX, could you check that you use the right device number in LV.
Are you sure you have only one NI-DAQ version installed on your computer?
Can you test your board with an example already created in LV?
Do not hesitate to give us results of those tests?
Cynthia Arickx
National Instruments France
(2,694 Views)
