11-02-2005
11:50 AM
- last edited on
06-22-2026
08:27 AM
by
Content Cleaner
11-02-2005 02:08 PM
Hi ,
I started a thread on this a few days ago reporting the same problem. I don't there's a solution just yet from NI
http://forums.ni.com/ni/board/message?board.id=170&message.id=149700&query.id=92956#M149700
11-03-2005 06:28 PM
Sbanerji,
Which version of LabVIEW are you using? If you are using version 7.1.1, it may be that you need to mass compile the VIs before the MATLAB script will work. If that does not work, I would suggest repairing the installation of LabVIEW, the following the steps in the KB that you referenced very closely. I would also make sure that you have run MATLAB to verify that the ActiveX files have been registered correctly.
Hope this helps!
Andy F.
11-03-2005 09:03 PM
11-04-2005 12:00 PM
