error 1047
hi,
when i run my application, it will show me this message:
''Error 1047 occurred at LabVIEW:  LabVIEW failed to send variable to the script server. Server:"" in Test.vi.''
thus,i try the solution founded in the website in order to reregister the ActiveX components but  the error message still appears .
please, is that any other solution for this error or how can i fix it.
thanks.
Regards.
(4,518 Views)
Are you referring to this article: http://digital.ni.com/public.nsf/allkb/2B3FF46C8512C4F786256CF30071BE53  ?
Do the Matlab examples that ship with LabVIEW work? If they work, but your script doesn't, then there's a problem with your script. Does your script work in Matlab?
Are you using any unsupported operations like input?
You could also look at this: http://forums.ni.com/t5/LabVIEW/My-solution-to-MATLAB-script-error-1047-and-error-1050/td-p/691782
(4,515 Views)
thanks for your help,
i try to run my programm..but its appear this error :
"script support DLL not found: Either this type of script node is not supported on this platform or the components needed by this script node are missing."
could you please resolve this error.
regards
(4,505 Views)
When you try to run what program? Yours, or the examples that ship with LabVIEW? Again, do the examples that ship with LabVIEW work? Are you sure you're using the right script node? There are several script nodes in LabVIEW.
(4,492 Views)
