error 1055 and error 1039
I want to call a VI but when I run this VI attached, I always get the error 1055 at the beginning, the VI opens and the property nodes that I have blink then I get another window of the error 1039.
I don't understand what exactly is happening.
Could you please help me with this?
Thank you in advance.
(3,089 Views)
The 1055 means that the Object Reference is invalid.  Try not using the Type Specifier VI Reference.  You don't need anything strictly defined here anyways.
(3,076 Views)
The error seems to be "invalid reference" error. Did you try to run the code from a local drive instead of running it through a shared drive?. Please copy the VI from the shared drive to a local drive and execute this VI and see what happens.
(3,074 Views)
