error 10687
Using Labview5.0 and traditional DAQ (AT-AO-6/10), I perform analog output from two VIs.
I made one VI (AO continuous generate) reentrant following the solution posted on NI homepage.
However, I still get error 10687.
Is there any solution for this?
Sincerely,
(2,970 Views)
Hi rock,
Thank you for posting to the NI forums.  I believe that you are referring to the following Knowledge Base entry.
Error -10687 When Performing Analog Output from Two VIs [broken link removed; article no longer available]
I have not found any documented issues where the steps suggested in that article did not fix the problem.  Did you try running the attached VIs?  They should definitely allow this functionality.  If you can run those VIs successfully, then try paring down your code until it is close enough to the contgenwithsingle VIs that it doesn’t generate the error.
If those attached VIs do not work with your device, please post back.
Ed W.
Message Edited by Ed W on 05-16-2007 01:51 PM
(2,956 Views)
