error -1073807339
Hi ive got a agilent 34970A scanner and a 3458A multimeter. i connect these to the computer using gpib and using a ni gpib usb-hs lead. using NI 2011 my code works. I downloaded all the labview vi for the agilent off of the net they work on labview 8 and higher. but the problem is i need to make them work in labview 7 so i opened labview 7 and recreated all of the files in 7. everything works except when i try to take a measurment. i get error 1073807339 come out from visa read in one of my vi. can you guys help. i can upload my programme if needed. i have set up the two agilent so that i can have 8 channels on the scanner and the multimeter can take any reading from any channel. thanks again
(3,271 Views)
Hi Joe,
your error is a timeout error. So no answer is arriving from the DMM or something similar...
Why don't you go to the downconvert thread to get the driver VIs downconverted to LV7?
(3,268 Views)
ok i have done that but. i cant upload all the vi's  because there about 40 of them. how else can i get around this problem. thanks
(3,262 Views)
Hi Joe,
ever heard about those archiver programs named ZIP or RAR?
(3,259 Views)
No i havent what are they
(3,256 Views)
Hi Joe,
it's nice to know you already learned to use an archiver...
(3,251 Views)
