error 1074360293 during highlight execution
Can someone help me is solving this issue? I am getting this error when I use the highlight execution. I am trying to capture an image through an external trigger. Attached is the .vi I am using.
Nachiket
(3,379 Views)
Are you getting the same error when you don't use highlight execution?
(3,371 Views)
Nachiket
Error -1074360293 is a timeout error. When you are in highlight execution mode you are slowing down the execution causing the timeout.
Ben64
(3,333 Views)
As it happens, I have two GigE Cameras connected to my PC, so I tried your code.  It gave me an error on the "Setting the Trigger Mode" Property, whether or not I used Highlighting.
I then attempted to learn about the BusType Property, but (of course) there is no Help for this Property.  I can tell you that my Cameras return neither of the numbers you show in your code, and if I wire an Indicator to that line, the Indicator shows "Direct Show", which looks as though it is an Enum, but again, Help says only "Unsigned 32-bit Integer", though if I Probe the wire, it shows the number 1230005101.  I can see some other possible values of this Indicator, which include FireWire and Ethernet, but that's all.
If I open MAX and try to find Camera Information (which include BusType), I can't find it.
I fear this may be one of the (many) "undocumented" "features" of IMAQdx ...
Bob Schor
(3,330 Views)
