error -10845 happend when dsa.vi loaded
i try to run all daq vi in the example with no problem (i try those example one by one). Then i load the dsa.vi example, all these example of daq can't run. error -10845 came in some program, and error -10608 came too in some program. Trigger timeout's led is on in the simple analyzer. It never happend before. Why it can be happend, and why ?
Please...i need your help. I use LV 6.1 in win98, RAM 128, with CPU Celeron 500.
(2,667 Views)
Both of the error you reported are of the same flavor.
They both indicate that the data buffer on the I/O card is filling up faster than it is being emptied.
This prompts two possible solutions;
1) Reduce the acquistion rate.
or
2) Increase the rate of data being read from the buffer.
Option #2 may be limited by your CPU and limited memory.
Ben
(2,667 Views)
I all ready do the 1st thing, where i can increase the rate of data being read from buffer ?
(2,667 Views)
