error 1097 after calling dll function which allocates memory inside
Thank you for your quick answer.
Yes, i am sure that the Allocate function cause the problem because all other function which only making register reading or writing works well, and i also tried an another function
which uses Allocate function as well but first calls an another function which writes some registers and i can see that function succeeds and the Allocate crashes.
I think i can get the source code for that function and i can post it here.
Tamás Szabolics
Message 11 of 12
(775 Views)
Accepted by topic author Tomzi
Problem solved.
I was a bit stupid because of some performance issues i should have add my user to Lock Pages Priviliges. That caused the error so now the LabVIEW application runs withour error.
Thank you and sorry for wasting my time.
Message 12 of 12
(764 Views)
