error 1097 in call library function
Hi Guenter Mueller
Now i have exported all the main functions relating to loading of mpusbapi.dll file . I have  exported  the  Load Dll () ,
AbrirTAD () function which is for opening operation and CerrarTAD () function which is for closing operation. Now i am calling all these three functions from my VI.
Now as i run my program again error 1097 occurs , when i press continue, this error again occurs and when i again press continue , a new error occurs which is in the attached doc file.
Message 11 of 34
(2,667 Views)
h
Message Edited by mhs100 on 10-18-2009 12:35 PM
Message 12 of 34
(2,667 Views)
The Visual Studio Debugger is quite clever. If it says, you are using the wrong calling convention, you can trust. If I remember correctly, you have configured the Call Library Function Nodess to use cdecl. Try stdcall instead. Or make sure that all of your exported function have the same calling convention, e.g. by specifying
__declspec(dllexport) __stdcall FunctionName (/*parms*/)
Guenter
Message 13 of 34
(2,659 Views)
Hi
Now when i am exporting all functions by using Std Call , the compiler gives 3 errors . I am now using  module definition .def method for exporting functions to avoid name mangling but i cant understand why there are errors while compiling.
Message 14 of 34
(2,642 Views)
I am sorry i forgot to attach the file.
Message 15 of 34
(2,639 Views)
The 3 errors come from your insertion of the definitions in .CPP. This is expected to be in a .DEF file. See the attached stuff.
Hope this helps, Guenter
Message 16 of 34
(2,631 Views)
Hi
Thanks for the sent file , now the 3 errors are removed and dll is made successfully. In labview , i am using std calling convention but still the same errors occur which i sent you before in the doc file . First error 1097 occurs , when i continue again error 1097 occurs . If i again press continue the visual studio compiler gives the errors.
Now all the functions in my dll code have the same calling convention that is std calling convention then why the visual studio compiler gives the error of wrong calling convention?
One more thing that please check the function Invalid error handle () and  send receive packet ().
Do i have to export these functions also?
I can't understand where the problem is. Why the daq is not communicating with labview. On the other hand the code in the pic controller of daq card is correct .Ihave checked .
The attached file mhsdll +def  contains the correct code and i am also sending the VI. The errors are the same as in the above doc file.
Message 17 of 34
(2,606 Views)
You may want to consider looking at the return types in the dll calling parameters. Are you sure they should be return by value rather than Pointer to Value ?
Also, make sure that the variable being used to store the returning value has been initialized.
Additionally, I believe that a return value for each of the parameters being passed must be declared in the call to the dll.
Message 18 of 34
(2,598 Views)
Hi
I dont think that the error is arising because of any of the incorrect data types. Please reply to my last post .
Message 19 of 34
(2,593 Views)
I have a question to ask that  the code of my dll which is mhsdlldef.zip . In this code ,  i have exported all the main functions such as   salidasdigitalesByteTAD() for digital outputs, salidasanalogicasTAD() for pwm output etc.
Almost all of the functions use sendReceivePacket()  functions in them , but i did not export sendReceivePacket() function .
The Question is
1) Do i need to export SendReceivePacket() function ? This function is used in every other functions body.
If i have to export this function also then the second question is
2) What values will i give to its parameters in the labview VI ? Because this function has six arguments and a return value , whose values are continuouly changing depending on the  function in which this function is called.
Regards
mhs100
Message 20 of 34
(2,581 Views)
