error 116
GoodMorning.I have a problem when I try to read data from binary file .An error 116 is appeared.
(5,909 Views)
Hi paparas,
i think you have connected the wrong data type. Can you give more informations?
Mike
Message Edited by MikeS81 on 04-22-2008 10:16 AM
(5,906 Views)
Hai paparas,
Hope this helps.
Mathan
(5,899 Views)
His inference is here.
- Partha ( CLD until Oct 2027 🙂 )
(5,887 Views)
I am getting the same error now, even though I am quite sure I have the correct data types. To get the data type for the Binary Read vi, I simplyed used 'Create Constant' from the data I had wired in to Binary Write vi.  The read and write commands are in separate VIs I have made, as one creates temporary files, and the other recalls the data.  I have posted two images of where I Write and Read, any help would be appreciated.
Aaron
(5,242 Views)
Nevermind! I solved it, found I had the inputs to the cluster crossed so the 2D read was trying to read the 1D cluster and vice versa... sorry for cluttering the forum!
(5,226 Views)
