error 1172
I am having the attached error. I have a labview module trying to send an email with gmail. It works fine when I am home using my local wireless network.
Now I am in a public library, and connected to the public network. And when the program is running I am getting that error.
I am guessing that windows 7 is using the public settings which blocks access thru port 587 I guess, not sure.
Any help?
Message 1 of 11
(6,093 Views)
It sounds like their Firewall may be blocking it.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 2 of 11
(6,086 Views)
Any idea what exactly to fix?
Message 3 of 11
(6,083 Views)
I would say talk to the IT person at the library, but I don't know how self-contious you are about uncontroled laughter at your expense.Smiley Very Happy  My suggestion would be, don't run it at the library.  Is this for school?
Message 4 of 11
(6,081 Views)
Is there away in labview to check is port 587 is open or alowed or usable before sending my email? This way, I will be sure that I will not get this error if that port is locked....
Message 5 of 11
(6,072 Views)
You could use the TCP/IP functions to open a connection on that port. If the Open function returns an error then you know that port is not open.
Message 6 of 11
(6,068 Views)
You could check the port using the TCP/IP functions as Smercurio has suggested or you could handle the error if it does occur.
Message 7 of 11
(6,065 Views)
Thanks.
Message 8 of 11
(6,056 Views)
This is what I am trying to do to check the port connection using localhost, but it I am receiving an error.
I am just home so everything should work fine.
Some help needed.
Message 9 of 11
(6,052 Views)
Accepted by topic author agyna
Try this.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 10 of 11
(6,043 Views)
