error 1172
I am getting the following error calling a .net libary.
Error calling method KB.KEAT.TestStandConfig.Reader.Importer.Read, (System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation.
 Inner Exception: System.FormatException: String was not recognized as a valid DateTime.) <append><b>System.FormatException</b> in profinet interface.vi
can anyone offer some suggestions as to what is happening. The .net  was created in net 3.5 and I have version 4.5
thanks
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(3,533 Views)
Add this file to your LabVIEW directory.  yes, right in the same folder as  "LabVIEW.exe"
Now, of course you want to know why.  See Here
OH FOR SHAME!  Cant attach *.config
here is the cleaar text
<configuration>
<startup useLegacyV2RuntimeActivationPolicy="true">
<supportedRuntime version="v4.0.30319"/>
</startup>
</configuration>
(3,516 Views)
I already have this .config file. Pointing to the appropriate version of .NET (4.0.30319) If i point it to v4.5.50709 it fails asks me to install it (it is in the program manager). The framework i am trying to use was built in v3.5 so should work in either version, but the only similar problem i have seen is this link [broken link removed] but it involves dates from .NET to labview, not the other way round
thanks for your help
(3,484 Views)
