error 1303 when installing RTE 7.0 on Win NT
I am trying to install RTE 7.0 on a Win NT 4.0 SP6 machine. It gives me an error 1303...Not sufficient permission. I have full administrator rights. Can anyone give me a clue?
(3,406 Views)
Was there a specific folder mentioned in the error message?
The most likely problem is that the System Account does not have full access rights to this folder. The Windows Installer operates under the System account. You need to check the access privileges on that account.
Hope this helps.
Naren
(3,406 Views)
Hello Wytech,
Thank you for contacting National Instruments.
Make sure you do have administrator rights by trying to copy and paste to the folder in which you are trying to install RTE.
Also make sure that you have permission to write to the specific folder if it is on a network.
Let me know if you any more questions.
Sean C.
(3,406 Views)
