error 1430
I am a fairly inexperienced Labview user and when I run the program I created in order to Read Analog Input Signals I get this error message 1430 <Occured at Open/Create/Replace File in NI_HTML_lvclass:Save Report to File.vi->Voltage - Continuous Input.vi> Possible Reason: Laview: The path is empty or relative you must use an absolute path. JPEG.
Any suggestions how to fix this error? It's probably pretty simple but I figured out would ask first before spending hours trying to fumble upon the answer on my own!
Thanks!
(5,165 Views)
Accepted by topic author mmmhmmm
You have a path control wired to "save report to file" and it contains only the word "JPEG". This is not a valid path. Use the browse button of the path control to select a valid path before running the VI.
(Currently, you can only select an existing file. If you also want to be able to select a new file, change the browse option of the control)
(5,151 Views)
Yep, now I feel embaressed. Thank you!
(5,102 Views)
