error -1906 occured at SoundVib_SoundLevel.Lvlib:SVL Leq Sound LeveL (N Ch).vi:3
 Hey all, I have this message error when I try to run my vi.
Possible reason,
Sound & Vibration: Multichannel measurements require that each signal has the same sample interval (identical dt or identical dr)
(3,115 Views)
It would be good if you can explain what you are trying to do and show us the code, instead of showing the error message.
(3,106 Views)
I am generating a analog signal and acquring the same signal. I want to visualise the generated and aquired signal on the sound level meter
as you can see on the attached vi. when I run the vi the error message ( error - 1906 occured at soundVib_SoundLevel.Lvlib:SVL Leq sound level (N Ch).
(3,055 Views)
