error 1967362033
I want to delete a database with the delete database VI. If I start the VI I get the error 1967362033 back. Possible reason is IAK-SHARED: (Hex 0x8ABC700F).
It would be great if someone knows how to handle this problem.
Thanks Andy
(4,007 Views)
Hello Andy,
please tell me what kind of NI-Software you use. Name and Version would be graet! Also your operationg system.
Thanks a lot,
Jan Kniewasser
Jan Kniewasser | Applications Engineer | Tel.: +49 89 7413130 | Fax: +49 89 7146035
(3,979 Views)
Hallo Jan,
thanks for help. I already solved my problem by using the delete funktion in the attach database VI. This delets the datas from my databas on the host. Then I can delete the database by using the delete database VI and it works.
Thank you again for answering and for shure there will be some more questions in the near future.
Andreas
(3,975 Views)
