error 2 NI configuration manager
Hi all:
     I am trying to start the NI configuration manager via the services section of the control panel. I need to do this in order to start the NI Device loader, which should start my NI myDAQ, which hasn't been starting up, and I think I've traced the problem back to the configuration manager. Whenever I try to start the configuration manager, I receive an error message stating that "Error 2: File not found". Does anyone have any ideas as to how I can figure out what files I need to have in order to start this up?
(3,010 Views)
What versions of MAX and DAQmx you have installed? You may be able to fix this by upgrading your drivers, or by repairing your MAX installation: http://digital.ni.com/public.nsf/allkb/FE6B641E86E55AF2862576DE00038001
Trevor B.
PSE
(2,971 Views)
