error -200073 when trying to reset SCXI module
Windows 7
LabVIEW 2017 with NI DAQmx drivers 14.0
PXI 1052 chassis with the following SCXI cards:
5 - 1102C
1 - 1308
1 - 1161
I can the chassis and all the cards listed in MAX without errors but I cannot reset, let alone use a test panel, without getting error -200073.  I've looked at the following:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000004ALqSAM
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000004B98SAE
http://digital.ni.com/public.nsf/allkb/FA32B0EAEEA81D2586256D5200693BD2
https://forums.ni.com/t5/Multifunction-DAQ/LabVIEW-with-SCXI-1001-chassis-SCXI-1600-usb-module-and-S...
I've double and triple checked the configuration.  Am I left with deleting everything and starting from scratch?
(3,031 Views)
correction I'm using LabVIEW 2014
(3,029 Views)
Hi Faustina!
I would rather try uninstalling NI MAX and installing it again. I suggest you download the lates version and than reset the NI MAX database.
(2,989 Views)
