error 200279 AI DAQmx NI PCI-6024E
I'm running a loop with an N-Chan AI Read vi,while  I run my LabVIEW programs Acquiring Data Continuously I get an error That says:
Error -200279 occurred at AI Read.vi:7
Possible reason(s):
Attempted to read samples that are no longer available. The requested sample was previously available, but has since been overwritten.
Increasing the buffer size, reading the data more frequently, or specifying a fixed number of samples to read instead of reading all available samples might correct the problem.
Could you please suggest to get rid of this problem..
(2,911 Views)
I am on my phone and can't look at your code, but did you try increasing the buffer size, reading the data more frequently, or specifying a fixed number of samples to read instead of reading all available samples? This might correct the problem.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,869 Views)
Hi Mike,
Thank you for your reply,
I had tried by increasing buffer size and for Fixed number of samples instead of reading all available samples, but still the same error repeats..
(2,849 Views)
