error -200279 DAQmx
I'm currently using the NI USB-6009 Data Acquisition hardware to take voltage readings across a Plant Microbial Fuel Cell that I have set up. When taking readings I get this error message "Error 200279" attached below.
Can someone please help me sort out this problem?
I've attached a pictureof my Labview code as well.
Thanks.
-Haunya
(2,862 Views)
Hi Haunya,
the message is quite clear: your software is too slow to keep up with your DAQ hardware!
You need to read your data more often (aka "faster") - or decrease the sample rate of your DAQ device.
It also often helps to use a producer-consumer-scheme (as offered in the LabVIEW example projects!) to decouple DAQ from data analysis/logging.
The most easy part is to get rid of ExpressVIs as they aren't made for speed/effiency…
(2,834 Views)
