error 200452 on AO.Idleoutputbehavior
I keep getting an error 200452 which is associated with my AO.idleoutputbehavior function. This error only appear when I stop the VIs. Every other functions of the VIs (acquiring and output) works fine. I changed the physical channel and it still shows up. I am not sure why I am getting this error. Has anyone ever encouter a similar situation?
Message 1 of 8
(1,895 Views)
Hi Ilias,
A lot of information is missing…
  • Mind to attach your VI? (Or atleast a sample VI demonstrating the behaviour…)
  • Does the error really appear on stopping of your VI? (Does it appear earlier without noticing?)
  • Which hardware do you use?
  • Which LabVIEW/DAQmx version?
Message 2 of 8
(1,889 Views)
The error text gives a strong clue: "Specified property is not supported by the device or is not applicable to the task."
Many common DAQ devices do not support this property for AO.  For example, I just tried with a general purpose X-series MIO device (PCIe-6341) and got the same error.
-Kevin P
Message 3 of 8
(1,874 Views)
The analog output cards such as 673x support this property, not sure about other mixed-IO card (Kevin confirms that X-Series doesn't support)
Santhosh
Soliton Technologies
Message 4 of 8
(1,857 Views)
Hi GerdW,
Thank you for your response and sorry for the late reply.
  • I am using labview 2019 with DAQmx 20.7.
  • I am using a PCI-6115 card with BNC 2110 board.
  • I only get the error message once I stop the VIs. I have not notice a breakdown when the code run.
  • I am still working on a sample VIs that only show this behavior.
I think the PCI-6115 should be able to support this AO.idleoutputbehavior function.
Message 5 of 8
(1,801 Views)
Hi Kevin_Price,
Thank you for your response.
I am using a PCI-6115 card. I think it should able to support this property?
Message 6 of 8
(1,798 Views)
Hi Ilias,
Are you sure - or "do you think"!?
Do you handle errors in your VI correctly? Can you even notice an error inside your main loop?
Message 7 of 8
(1,793 Views)
This could as well be because of an incorrect error handling and not really because of DAQmx, please share the VI for review (in LV 2016)
Any reason you think this is the case? (were you hoping for it to be supported or are you sure it is supported?)
Unfortunately, it is not supported by PCI-6115
Santhosh
Message 8 of 8
(1,788 Views)
