error -20062
hi,
i'm getting the error -20062 when i try to solve a matrix system. has anyone
an idea, how i can increase the iteration number or if there is somewhere an
other matrix solver?
thanks in advance
ralf
(3,476 Views)
I have a couple of questions for you that might help clarify the problem:
What program are you using to solve your matrix system?
Which specific vi in your program is causing the error?
Also, if you could attach the smallest piece of code that illustrates this problem, that might help as well.
Thanks.
Matt Kisler
Application Engineer
http://www.ni.com/ask
(3,476 Views)
I'm using LabVIEW Version 6.0.2
To solve the matrix system I use the "Solve Linear Equations.vi" and
from this VI i get the error code -20062
I hope this help a little
Thanks a lot for the answer,
Ralf
"Matt K." schrieb im Newsbeitrag
news:506500000005000000244E0000-1005954886000@exchange.ni.com...
> problem:
> Thanks.
> Matt Kisler
> National Instruments
(3,476 Views)
Could you go ahead and attach your vi so I can take a look at it? Thanks.
Matt
(3,476 Views)
