error -2147024809 Exception occured in AgtLAServer. The Vi works as a top level vi but not as subvi.
Hi everybody,
I got an error message (code –2147024809. Exception occurred in AgtLAServer.Instrument.1, Error opening file or file is not a valid logic analyzer file format 'C:\Documents and Settings\ehoukhe\Desktop\Exjobb\radarstyr\data\xml\trigg.xml'.. in Logicmain.vi->manuel.vi) only if I run it as a subVI. But when I run it us a top level VI I got no problems, it just works perfectly.
The error occurs in the open node. All other nodes work perfectly in both cases (subVI and top level VI).
Any suggestions please
(3,615 Views)
i forgot to mention that i'm using COM Automation to configurate a logic analyzer (Agilent 1690AD).
(3,608 Views)
Never mind...
The problem is solved.
thanx anyway.
(3,602 Views)
My friend,
I am also working with logic analyzer16700 and I am also facing the same issue.Can u please let me know how u solved the issue.
(3,410 Views)
Hi rabishankar,
This forum post is about 3 years old so I don't think he will be able to answer you.
Could you please talk a bit more about your setup and what you are doing so that we can help you out? Thanks!
Rasheel
(3,390 Views)
Thanks a lot for your reply.I solved the issue by adding a node to close all the modules before running the Code.Now its working.But I am facing a small problem.I am putting it as a new thread.Please visit the thread and answer my querry.Looking forward to your reply.
Rabishankar
STmicroelectronics.
(3,378 Views)
