error -2147217900 while using database connectivity tool in labview
hai..im new to create database..with the help of examples available im getting some ideas..even though when i try to create a table i get errors which is attached with this thread..kindly anybody give suggestion to create database using the tool kit or suggest resources link to do..
(5,716 Views)
Can you post your code or part of a code.?
Nitzz
(5,715 Views)
Accepted by topic author Sumithra_Nagappan
i got it..i was trying to create a column  Pass/fail,i did mistake here..and corrected it..have to use pass_fail
(5,712 Views)
But i couldnt insert special characters like "/,-,(,)"..do you know how to do this?
(5,711 Views)
look for the valid SQL parameters and you will find that you cant use the characters you want to use.
Columns names must:
1) be Alphanumeric
2) Start with an alpha character (not allowed a column "10_bar_pressure_test"
3) the only special character I have found so far that is allowed is underscore  - i.e. no spaces, commas exclammations full stops or other things.
Hope this answers your question. (Basically it is a limitation of SQL programming, not LabVIEW and you must work around it.)
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
(5,686 Views)
