error -2147220719
Got this message while trying to run the DAQmx and connect to my sensors after the Labview was loaded. "Error-2147220719 occurred at DAQ Assistant. Possible Reason (s): MAX: (Hex 0x80040311) The client process has been disconnected from the configuration server. If this problem persists, please note the steps you performed that led to this error and contact technical support at http://ni.com/support."
Wonder if anyone knows how to solve this problem. Thanks.
(4,958 Views)
Hi YenTC,
Did you by any chance hibernate the computer?  It seems like this might be from a known issue with LabVIEW.  Have you tried restarting LabVIEW after you get this error, or restarting your computer?
Julian R.
(4,932 Views)
Hi, thanks for your reply. I tried several times restarting the software, the computer, unplugged the usb connections and re- plugged in but nothing helps. It just happened all of a sudden, and the loading of the software was extremely slow. Could this be my laptop problem? Cheers.
(4,912 Views)
Hi YenTC,
What version of DAQmx drivers and LabVIEW are you using?  If your DAQmx drivers aren't up to date, we should definitely update those.  Also, does this happen after you hibernate your computer?
Julian R.
(4,881 Views)
