error: -2147220730
hi,
I'm trying to connect and harvest data from a cRIO 9012. The cRIO unfortunately is not possible to physically reprogam as the ongoing system cannot and I do not dare not touch it for fear of losing what works today.
Though I have to add annother cRIO for further instrumentation.  Most preferably with one and only one windows.exe harvesting from two rios.
The exe. harvest throuh network shared variables from a lib.lvlib on the cRIO
First attemt to connect to the old rio returned an error message as following when deploying
deplyment failed (
error: -2147220730, MAX: (Hex 0x80040306) Internal errror: The requested attribute change does not match the type of the attribute.
Distrinute system manager shows the variables and I've got the same variables  ( int8 Int32..  etc.)
(3,174 Views)
Hi josens,
Why can you not reprogram your cRIO? Also, do you have any third party drivers installed?
(3,084 Views)
