error -2147221480 occured at building dll stub
I am trying to create a LabView Dll, however i keep getting this error whan i attempt to build it. I have created Dll's before but all of a sudden it just stopped working. Has anyone else seen this and can shed some light? I'm using LV 7.0
(3,220 Views)
Thank you for contacting National Instruments.
I understand that you're experiencing issues when trying to build a LabVIEW dll.
Fortunately, there is more information regarding this problem within our online knowledge base. See the following link.
http://digital.ni.com/public.nsf/websearch/0DFFE3BA861E689686256CAA006BA7F1?OpenDocument
I hope this helps. Please don't hesitate to notify me if you need further assistance. Have a great day!
Kind Regards,
Joe Des Rosier
(3,220 Views)
Thanks for the reply. i have actually seen the document you are talking about.
However my dll is called PowerSpec.dll not Labview.dll but it still does not work.
(3,220 Views)
I am sorry that the previous solution didn't fix the problem. I found another knowledge base entry that may be the correct solution. Please follow the instructions on the following link:
http://digital.ni.com/public.nsf/websearch/51A4147B66E59BA286256C690077109B?OpenDocument
I honestly feel that this will cure your problem. However, if you still experience the same error after trying this second fix, please let me know so that I can properly escalate the situation within our support team.
I hope this helps. Please keep me updated.
Kind Regards,
Joe Des Rosier
(3,220 Views)
Joe,
That seems to have fixed the problem.
Thanx
(3,220 Views)
Good deal. I'm glad that you're up and running now.
Best Regards,
-Joe Des Rosier-
(3,220 Views)
