error -2147417851 for example write table to XL
Hi, I want to save array data into excel. I try the example    write table to XL.vi
but error -2147417851 comes out
I have no idea to solve this error.
Can anybody help?
Thank you very much!
(4,306 Views)
Please attach the VI you are using.
(4,299 Views)
The example vi works fine (LV2009 with Excel 2003). What Excel version do you have installed on you machine?
Ben64
(4,296 Views)
Oh, here is the example
(4,285 Views)
It is work fine in another machine with LV 2010 and Excel 2007.
But for this machine with LV 7 and Excel 97 there is an error,and i don't know why.
(4,283 Views)
Accepted by topic author Edith
Each version of Excel has its own object reference, and Microsoft has made changes to some of the classes with each version of Excel. Thus, it is highly likely that an example will work with one version of Excel, but not another since the properties and methods will have changed. The only thing you can do is that you have to look at the documentation for the Excel object model on MSDN to see what's different.
(4,272 Views)
Oh, yes  I upgrade excel to 2007, still using LV7.1, it works.
Thank you so much!
(4,260 Views)
