error 2147467259 Can not connect MAX
I have a real time target. Ii works well till today!
Its hour was incorrect and i change it from the Bios. I do not change anything else. I just correct hour form 15:00 to 14:30.
I restart to computer and ı recognıze that from my host computer ı can not see devices (cards) on RT from MAX.
In the deskop of the rt target the following writes:
no connect to MXS!
[nidevldp--224--tDeviceloader.cpp--------] MAX configuration files may be corrupt.
[nidvldp--245--tdeviceloader.cpp] status=
tsatust contents:
Error 2147467259
component name=nidevldp
file name=p.\Masurement\infrastructure\devld\trunk\150\source\mxscnfigwrapper.cpp
line number=156
Whats happening? ı do not understand
(3,931 Views)
Hello Eesen,
Oh no!  We'll get that up and going.  What kind of target is this?  PXI?  Desktop ETS?  It looks like changing the BIOS indirectly caused a corruption in the connection between the target and MAX.  Did the crash create an error log file?  You can find where the log file is located on a RT target here.  If so, what does the file say?  Have you been able to repeat this crash?  If a file has become corrupt, we may need to reformat the target.
Have a great week!
Janell R | Applications Engineer
(3,916 Views)
I just reformat RT target,
Thank you for your repply
(3,909 Views)
Were you able to find out what caused this error.  I am also having the same issue with DELL PC GX270 with LV RT 8.2.
Fari
(3,767 Views)
I can't find the reason so I reinstall everything. As a guess, to change BIOS setting can cause this.
(3,755 Views)
