error 268435462
Hello everybody,
When I try to launch my program, I have this error which is appeared. I don't understand why because all it's good (program, devices, IP).
And when I try exactly the same program with the same configuration in an other computer, it's works.
Do you have any ideas?
(3,312 Views)
Does ES4xx mean anything to you?
It sounds like it is part of a device driver or activeX component.  It is installed on the PC where your program works.  It is probably not installed on the PC where your program doesn't work.
Try installing or reinstalling what ever drivers are associated with this device you are working with.
(3,308 Views)
Yes ESxx mean something for me.
Yesterday I havereinstalling the driver for this modules but anything change.
(3,304 Views)
