error 2983 while building an exe which has source control vis
hi,
I'm tyring to build an exe for a code that has source control VIs in it. i get error 2983 while running the exe. i did some research and found that about the three parameters that need to entered into the ini file. i did that and also added the NI_SCC_P4CMD.lvlib to the dependency. i still get the error. not sure what wrong i'm doing here. below are my variables in the ini file
SCCConfigData="TRUE;TRUE;;;;"
SCCProviderName="Perforce Command Line"
SCCProviderLocation="P4CMD"
(3,482 Views)
Are you using Perforce as your SCC provider?  Are you trying to integrate it into the LabVIEW Development environment?
I don't really understand your question or problem.  Many of us (I, among them) use some form of Version Control Software (I, myself, use Subversion) to manage our LabVIEW code.  But when actually working with LabVIEW (i.e. running LabVIEW in "development mode", including building Executables), the SCC is basically nowhere to be seen, and in no way enters into the Build process.
If you are, indeed, using Perforce, and if Perforce needs, somehow, to be "integrated" into the LabVIEW Development system, then someone else with experience in this provider will have to come forward.  However, I've had no trouble at all using Subversion to manage my LabVIEW code repositories ...
Bob Schor
(3,466 Views)
I am using perforce as my scc provider. i am using the source control vis to get some revision information in the development environment.
(3,449 Views)
Accepted by topic author socalscouser
nevermind folks. i added the folder to the always included list instead of the .lib file and it works great!
(3,427 Views)
