error 42 create folder
Hi everybody,
Test System is WinXP with LV8.2.
In the course of the vi I dynamically load VIs, create folders etc without a hitch. However after compiling to an executable,  I get error 42 when creating a folder or an error 8 when trying to open a vi reference.
Help would be much appreciated
Schorsch
(3,841 Views)
Hi Schorsch,
are you sure that your paths are correct? If you build an executable, then the function "getcurrentvi´spath" gives following back. C:\your.exe\your.vi.
Hope it helps.
Mike
(3,840 Views)
This, this and this may help.
(3,836 Views)
I have a little sub VI I always use when opening/creating files/folders. Gives a relative path to the file. (It's in 8.5 can save for something else if you need.)
(3,835 Views)
Thanks for vi,
gave me an idea and solved the problem! Smiley Very Happy
(3,832 Views)
