error -50103. occurred when I am trying to read to measure two analog channels.
  I have a NI USB-6366 DAQ, and I used two different physical channel which are Dev1/ai0 and Dev1/ai1 to collect data in parallel. However sometime ai0 channel DAQmx start task generates the error -50103, and sometime the other channel generates the error. These two channels never both work at the sametime, here is a picture of my code, please help me to solve the problem. Thanks very much parallel coding
(3,002 Views)
Try searching the forums for the message before posting.  Search "error 50103".  You'll find hundreds of threads that will tell you the answer.
(2,993 Views)
