error 50103
I am quite new to Labview and I am experiencing problems related to error 50103.
Here is my problem : I need to acquire a frequency, a an edge counter and an angular position, using the same optical encoder. I use the chassis NI cDAQ 9172, NI 9411 and NI 9401.
I am able to simultaneously acquire the frequency and the edge counter with the same module NI 9411, respectively with Mod5/ctr0 PFI 1 and Mod5/ctr1 PFI3.
But when I try to acquire the angular position with NI 9401, I have the error 50103.
I understood that I can only have one DAQ task per DAQ device, but I don't know why the fact to add a DAQ assistant that does not use the same module is not possible.
Please sea attached my program. (DAQ assistant : edge coutner, DAQ assistant2 : frequency, DAQ assistant3 : angular position)
If you could help me on thaht issue, I would be most grateful.
Thank you and sorry for my poor english.
(4,676 Views)
This seems eerily similar to http://forums.ni.com/t5/LabVIEW/error-50103/m-p/2094694
(4,668 Views)
Not really, because I am able to acquire frequency and edge counter on the same module (NI 9411) and no error appears (whereas I thought it should...), but when I want to add another module with the angular position measurement (9401), then there is an error, and this is what I don't understand.
Thank you
(4,661 Views)
Not really?????
It was almost word for word the same post as the other message.
(4,648 Views)
