error 536805376
I am currently using LabView 2011 and with that DAQNavi assistant 3.2 and the device used is of Advantech USB - 4716.
Everytime i run my program after all the configurations it prompts me the error  :
Error-53680537 occurred at ToErrorCluster.vi
reason(s) :-  get unique temp file name failed
and then redirects to daqnavi assistant's block diagram which then starts running.
The examples given in the LabView and DAQLabView are running fine but whenever other programs are run, it shows the error.
P.S. The programs were running fine until we connected 5V power supply, not sure this being the reason or a coincidence.
Thank you in advance.
(4,735 Views)
That is not an NI product.
Go ask Advantech.
(4,726 Views)
Even when the device isn't connected, it shows the same error!
(4,721 Views)
can you show us ur program
or tell us in detail in what mode ur acquiring the signal
(4,719 Views)
I am sorry but i cannot show the program as the computer on which we work cannot access the internet and sharing or carrying memory devices isn't allowed in our organization.
I have just started doing LabView and therefore have made VI's only for analog input and output.
(4,709 Views)
