error 6 occured at open file+.vi:open file
Hi
Iam using lab view 7.1 licensed version.But when i create a stand alone application  and install it in a 4gb touchpanel(ADVANTECH TPC 660G B1-E).iTS WORKING PERFECTLY FOR SOME TIME.But after some time i get an error (error 6 occured at open file+.vi:open file).Iam attaching the snapshot
plz help me out
ekanth
(3,339 Views)
This indicates a problem with your code. Since you haven't shown us any code we can' tell you what the problem is. Are you trying to open a file that's open by another application? Are you trying to open a file that's on a network, and the network is temporarily unavailable? You should know what file it's trying to open - after all, you wrote the app, right?
(3,334 Views)
iam trying to open a file that's open by another application
(3,330 Views)
Well, there you go then. This is usually not allowed, especially if the other application has a lock on the file. What's the file type, and what's this "other application"?
(3,315 Views)
