Showing results forĀ
Search instead forĀ
Did you mean:Ā
error 6
Did you also create an array of errors so you could see exactly when the error is occuring? Have you eliminated the different List Directory functions as the source of the error?
Message 11 of 14
(1,937 Views)
Today i searched an answer to my pb. I want to delete a directory and the task (DEL) i put in my code delete maybe only the files not the directories.
i only see it because when i run the part deleting files in the directory of temperatures alone, it works well.
Message 12 of 14
(1,926 Views)
You can only remove empty directories, as clearly stated in the LV help for this function. Delete all files and subdirectories within a directory before removing it.
Paolo
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 13 of 14
(1,925 Views)
That was the pb Thank you very much.
Message 14 of 14
(1,922 Views)
