error -63192
Hello everyone
I have the following error in MAX and I don't not which is the reason.
"Error -63192 (kRIOStatusInvalidResourceName):Either the supplied resource name is invalid as a RIO resource name, or the device was not found. Use MAX to find the proper resource name for the intended device."
Attached are 3 captures that show the error in MAX.
Iñaki
(4,341 Views)
Maybe you can look into this link? It should be related to your problem: http://digital.ni.com/public.nsf/allkb/FF92DCBBA48A12CE862576C70003CD95?OpenDocument
Warmest regards,
Lennard.C
Learning new things everyday...
(4,194 Views)
