error -63192
Can anybody help me?When I running a labview fpga example, it always shows this error, and i do not kown how to resolve the problem.
it shows "labview called another software component, and that component returned the following error: error code:-36192
   the error comes from _nirio_device_open.vi:1
The error is showed in the picture.
Thank you very much!
(4,039 Views)
Could you pls give a more detail discription of your platform,such as the hardware and  the software version? Make sure you have identified the cRIO target in your FPGA project before run the program.
(4,015 Views)
