error 7 application builder invoke node
I get this error when I tried to build an application. "Error 7 occured at Invoke Node in Dist read linkage.vi-> Dist Cmp Settings to Disk Hier.vi-> Dist Build App Image.vi-> Build Application.vi Possible reason, LabView: File not found.....and then NI-488 Non Existent board." Anyone knows why? I was able to build application just fine last night. But then when I tried to build it this morning, that's the error that I got. Thanks.
(4,529 Views)
Check the info in this link:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=50650000000800000016730000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0&USEARCHCONTEXT_QUESTION_0=Error+7&USEARCHCONTEXT_QUESTION_S=0
(4,529 Views)
Here are a few other links that may help you figure out what may be causing this error.
When Running My Executable Made in Application Builder it Gives ERROR 7
Error 7 at Invoke Node When Building a LabVIEW Executable
Error 7 When Building Applications and DLLs That Use the LabVIEW Report Generation Toolkit
Feroz
(4,529 Views)
The other folks have pointed you to some good links. Usually when this type of thing happens, loading the top-level VI into memory and doing a "File >> Save All" is fix it.
Good luck.
(4,529 Views)
