07-02-2008 01:58 AM
07-02-2008 07:32 AM - edited 07-02-2008 07:35 AM
You can force LabVIEW to recompile the entire VI hierarchy in your project with CTRL+SHIFT+Run Button.
Have you imported some old VI's into the project? From a previous version?
Did you add files since creating the build parameters? You may want to delete the build parameters and create a new one.
RayR
07-02-2008 07:39 AM
07-02-2008 07:54 AM
Thanks George... 🙂
Especially if code moved around (Copy / Paste to another folder / backup, etc..)
07-03-2008 12:24 AM
Thanks Ray and George,
I was using VIs of 7.1 version for 8.5 builder.
I deleted the previous build parameters and created a new one, it was sucessful.
sriveni
07-03-2008 07:34 AM
