error 85
I know this has been asked before but I do not get why I am receaving this code.  The system ran fine for a while and then all of a sudden I get this code all the time.  It worked before and I did not change anything that has to do with that scan part.  I worked with the DAQ assistant a little and then I wanted to test if my work had any effect and then scan failure.  I am lost.  The string I am scaning is a position response that will be a #_# with the "_" meaning a space. I thought this is how I have it set up but maybe I have a error I cannot see. Also the # can be any real number.  Thanks for the help and the vi is attached.
(3,562 Views)
Also when the error message comes up if I say to continue it will make a measurement and display the data but the error pops back up impeding more readings making it impossible to get countinuous readings.
(3,557 Views)
Accepted by topic author H2Oyeah
I figured my issue out.  It was a timing issue as I was overloading the scan vi with to much data.Smiley Indifferent
(3,546 Views)
