error Reading tdms files with a FOR loop
I am trying to read 3 tdms file and then append the 3 waveform to 1 single waveform. What I was found is, reading the tdms file and append the waveform within the same FOR loop will cause the data loss problem.
I have tried the "flush tdms, defrag tdms .. throw memory" .. none of them could solve the problem. Then I try to use 2 separated FOR loop and the problem resolved.
Just wonder why this happen. Can some1 there let me know if I m doing something wrong ? Thanks.
Here I attached the screenshot, 2 VIs (1 with problem, another 1 solved), and the 3 tdms files.
Thanks for viewing it.
Message Edited by engwei on 04-02-2009 02:36 AM
(3,243 Views)
No error version
Error version
Message Edited by engwei on 04-02-2009 02:39 AM
(3,241 Views)
Hi engwei,
in the no error version the wfmSize is connected in the other not. Maybe this is the reason.
Mike
(3,236 Views)
Thanks for the reply .. ya maybe.. will check it. Thanks.
(3,126 Views)
